brains
ojhk@hotmail.com's avatar
brains
tha mazda's avatar
tha mazda
My brain to the truck is still located under the driver seat and i was wondering if anyone could help me, because i just noticed yesterday that it was unplugged and was wondering if anyone can tell me were to plug it in?Thanks
1lowfatkid's avatar
1lowfatkid
i think they will only plug in one way? but im not sure
tha mazda's avatar
tha mazda
but i dont know were to plug it in.
drpdmazda
if im not mistaken that is the brain for the power brakes, the main computer for the truck is behind the passenger side kick panel, so if the one inder your seat is unpluged its probably because the previous owner was having problems with the abs system,
tha mazda's avatar
tha mazda
well the previous didnt have problems because there isant one...were do I plug it back on??
PleasuresBurban's avatar
PleasuresBurban
The main computer for the truck is behind the passenger side kick panel
tha mazda's avatar
tha mazda
ok Thanks everyone...now were do i hook up the abs system again?
plantedleif's avatar
plantedleif
Any luck with going thru a Haynes repair manual? They have a wiring schematic that you can look at which might help you out.
I dont understand why it is hard to see where the harness plugs into the computer, seems like it would be obvious.
My Mazda is an '89 and it did not come with anto-lock breaks, otherwise I would be able to give you a more definative answer.
drpdmazda
yeah the plug will only clip in one way, just look at the brain and look at the plug, there should be a clip on the top of the plug itself, then look at the brain, there should be one side higher than the other, i think its the top side, that is where the clip slides into, make sense?
tha mazda's avatar
tha mazda
see its plugedinto the abs system but I dunno were it plugs under the dash.
