Full Size Truckin General \  Fiberglass for Dodge Ram
views 373
replies 7
following 5
Chevyguy   +1y
Does anybody know where I can find Fiberglass bedsides for a 2001 Dodge Ram? I am also looking for a 6" Cowl hood for the same truck. Its for our shop's race truck.
Low_SST   +1y
you wont find a 6" cowl hood but you can track down the flares from ebay or the stealer ship. What motor are you using for a racing ram that needs a 6" cowl hood? half of the motor is under the firewall so i dont get what the 6' clearence is there for.
Chevyguy   +1y
I work at TS Performance and we have a 01 Dodge Ram 3/4 ton with the Cummins Diesel in it. We are wanting the cowl hood to direct air over the cab. So far we have run 10.96 in the 1/4 mile at 123mph. This next year we are able to shave some weight off the truck and need to get a fiberglass hood and bedsides. If you want to see the 10.96 run, go to our website at tsperformance.com
Low_SST   +1y
you would probably have to make one because ive never seen one. i would lower that ram a little to get better aerodynamics. http://www.rm-indy.com/
this website has a ton of weight reduction things and other tweaks and the time it dropped off the et's.
Chevyguy   +1y
We have lowered it some already but we are going to take it down some more. The biggest thing holding us back is the fact its a 4wd. We have to leave room for the front axle.
Low_SST   +1y
i would make it 2wd and drop all the weight from the 4x4 stuff.
Chevyguy   +1y
We've tried running it in two wheel drive and all it does is roast the tires. We have to run in 4wd because we leave the line at 20 lbs of boost and spray plenty of nitrous as soon as the driver comes off the brake. As the truck sits right now we can get all four tires to spin with DOT slicks on it.
danshoods   +1y
I CAN BUILD YOU THAT HOOD,IF YOU WANT TO SPEND THE MONEY ON PATTERN WORK AND MOLD BUILDING.
I'M IN NC I'VE BEEN DOING THAT KIND OF WORK FOR OVER 20 YEARS.
HIT ME BACK IF THIS IS SOMETHING YOU WOULD LIKE TO PERSUE.
DANSHOODS@AOL.COM
