TRUCK WONT LIFT
14 following
TRUCK WONT LIFT
cdk1978
IV GOT A BIG PROBLEM MY TANK IS FULL BUT WHEN I HIT THE SWITCH MY BLAZER ONLY RAISES ABOUT 1 INCH
matchead88's avatar
matchead88
it can be a number of problems. Check that all of your wires are hooked correctly, switchbox F-up, if its cold the valve might of frozen or your airline, i'm not an expert but try checking these things, if thats not it than it might be that you just need a new valve or something. Good luck
2LOW4U's avatar
2LOW4U
are none of the corners/sides lifting?
Low_SST's avatar
Low_SST
how much psi is in your tank?
cdk1978
Tank builds up enough pressure to shut off the compressor but truck will only lift 1/2 inch, no more.
BS
beyond static
you're having problems with front or back? What size bags do you have?
tooleyhc's avatar
tooleyhc
It might ba a faulty pressure switch.
Do you have a gauge that has a tank pressure reading?
krazeryn
I second this....Get a gauge on the tank or just bypass the pressure switch and see what happens.
Gotmods1
maybe you have alot of water in your tank taking up the air space. some guy came to me saying he only got 1 good lift before comp turned on but used to get about 3 lifts. he had a 6 gal tank & it had a shitload of water in it, i drained it & worked better. havent heard from him in a few months
bagged89S10's avatar
bagged89S10
where do you live? Is the temp. cold (below freezing). The water in the lines and tank could be frozen causing problems.
s10
last post by baha +1y
