Chevy/GMC Trucks \  truck stopped running for no reason
views 284
replies 14
following 11
ixenn   +1y
hey guys im trying to get my truck back on the road by tuesday and im getting close but today it started and died because the battery was dead and i had the guages off which makes the alt not work .but anyway i got another battery and hooked up the guages and now it just turns over almost cranks but instead blows a puff of white smoke out. i have just replaced the plugs and wires and it was running real good so i don't konw why this is happening. does anybody know anything i can try. Also the fuel pump and fuel filter are new and it was running with them.
fuller   +1y
yeah some1 please help us before i blow that bitch up
sjudd86   +1y
ive seen alot of fuel injected vehicles just stop running after running good, Alot of time the first thing i check is the map sensor, try un plugging it and plugging it back in, hope that helps
ixenn   +1y
yeah i've unplugged everything even put a new TBI gasket on it. nothing is working.
sjudd86   +1y
have you checked your timing, maybe it jumped timing because of the low battery, also are you positive all your plug wires are in the right spot
fullyshaved   +1y
i would say check timing also
ixenn   +1y
yeah my friend is saying timing too and that i prolly need a new belt. hes going to replace that tomorrow.
chunky_thunder   +1y
my gas line come off one time underneath my truck and it quit running
fuller   +1y
cant be fuel, gas is spraying in the throttle body and we've poured a lil gas down in there and it still doesnt start up..it acts like it wants to but it sputters a lil bit then kinda smokes thru the tbi
flameds10(tyler)   +1y
what size engine is it, i got a 4.3 vortec in my 93 s10 and it was turning over but the fuel pump wasen't workin, ended up being the fuel pump relay, its a little plug on the drivers side of the firewall
