Foreign Cars (honda, etc) \  srs(safety restraint system)light stays on
views 1140
replies 16
following 12
shawnswhip   +1y
my srs light has been on in my car for a while now... i tried disconecting the battery to see if it would go off, but no luck!!! any ideas to make it disappear without paying some fool $90 to hook it up to a diagnostic system????
ir8st8   +1y
Edited: 2/6/2006 10:37:11 AM by ir8st8
PULL THE BULB! LOLSEIROUSLY IF THE BATTERY TRICK DIDNT CLEAR IT U NEED TO HAVE IT SCXANNED TO SEE WHAT THE REAL PROB IS...
jetts   +1y
stop being a gangster and put your seatbelt on
time1   +1y
Its the airbag module,it might be under your seat. dont waste your money taking it to the dealer to figure it out. get another airbag module from either the dealer or a junkyard and pop it in.
loudciv   +1y
Edited: 2/6/2006 11:58:01 AM by loudciv
Originally posted by shawnswhip
my srs light has been on in my car for a while now... i tried disconecting the battery to see if it would go off, but no luck!!! any ideas to make it disappear without paying some fool $90 to hook it up to a diagnostic system????2 things you need to do. find out where your srs diagnostic plug is (mine was blue & under the glove box near blower motor). then get a the service manual to your car (usually can find them on line if you look hard enough). once you find the manual, put a paperclip in the plug as a jumper. turn the car on & the check eng light should blink. count the number of blinks & thats you code. for example: long blink=10, short blink=1, so ---,---,-,-,- would be a code 23. hope you can understand that. the manual should have the procedure in it too.
shawnswhip   +1y
well... i hooked up an obd2 autoscanner up to it(plug behind the ashtray) and it passed and said no codes detected on all... BUT THE LIGHT IS STILL ON....i hooked it to the data link connecter(behind ashtray) do i need to hook it up to the service check connecter(behind glovebox) is there a difference in the two????
time1   +1y
change the AIR BAG MODULE!
shawnswhip   +1y
hey adam (loudciv), where exactly is the port to hook it up? i see a blue box next to the blower motor under glove box but it doesn't have the same hookup as the port behind the ashtray. theres two plug ins in the blue box, one is filled with a connection, so what/where does the pin jump/or go??? thanks for the help so far. shawn
2lowtoy   +1y
I have had problems with the clock spring in a couple civics they break and turn the light on cause the diag mod dose not see the module in the steering wheel no longer
loudciv   +1y
Edited: 2/7/2006 11:06:17 AM by loudciv
Edited: 2/7/2006 11:03:58 AM by loudciv
shawn, reread my post. there is no port. it is a blue plug w/ 2 wires in it. use a paperclip to jump the 2 wires. turn the car on & count the number of blinks. you will need the correct service manual to diagnose. check some real tuner sites for a download to the manual (not a haines manula that you can buy at parts store, but the dealership service manual). i know they're out there i've seen a few places w/ them, although i cant remember em now. check this site & see if it helps.http://www.troublecodes.net/honda/
heres a start to try & find your manual. you will have to create a user account before you can download.http://www.hondahookup.com/manuals/
these other guys may be correct, but what i've told you, can diagnose any check eng / mil light that you may get.
