wiring a horn..
ricky@whynotfab.com's avatar
wiring a horn..
whynotfab's avatar
whynotfab
i got a set of the PsychoBlaster air horns, and want to hook the valve to my regular horn button rather than a seperate one.
I have an aftermarket autozone special steering wheel, and when i pop off the horn button.. it has 2 prongs on it, and theres a single wire exposed inside where i removed it. that wire is hot though (i tested it) but i dont see how id run FROM that hot, back to my horn's valve. one thing though.. is when i touch that hot wire to a ground, or test it with my light.. something clicks around the fuse box area. i dont have a fuse panel label or a book.. so i was wondering if anyone had any suggestions. thanks
time1's avatar
time1
find the plug in the engine compartment that runs to your stock horn and splice a wire from there to the valve on the air horn.
whynotfab's avatar
whynotfab
I dont have a stock horn lolwouldnt even know where to look
time1's avatar
time1
the wire is still there somewhere...look somewhere around the front passenger corner. its goin to be 1 wire with a regular female slide connector.
whynotfab's avatar
whynotfab
I found 2 loose wires with female plugs on the end.. one seems like its also spliced into or just wire loomed together with one of my bumper markers.. the other i cant tell where it comes from but it only has 1 metal piece in it. the first one is larger and has 2 slots in it
time1's avatar
time1
test those with a test light and someone pressing your horn button.
whynotfab's avatar
whynotfab
ill have to wait till theres someone around to help
there is a click under the dash for sure though.. what could that mean?
time1's avatar
time1
when you press the horn button?
whynotfab's avatar
whynotfab
Yea.. well actually not when i press it. its not connected. its when i remove the button and touch the wire to anything else
time1's avatar
time1
HMMM....DOES IT CLICK WHEN YOU GOT IT HOOKED TO THE HORN BUTTON AND THE BUTTON IN THE STEERING WHEEL?
