Air Ride Suspensions \  bottom bars length
bottom bars length
Air Ride Suspensions Q & A
views 252
replies 16
following 13
dubDyme   +1y
just built a rear clip for my truck...just wondering if a 30" lower bar is too long to mount the bag on. also for the top, im planning on running a wishbone....any problems
settintrendz   +1y
no, 30" is not too long. the longer your bars are, the less arc you'll have. just make sure you gusset the bottom of you lower bars if you're gonna run a bag on it. and as far as running a wishbone goes, as long as you run all bars (lowers and wishbone) forward, you'll be fine. thats the best set-up. two more things to keep in mind... your upper and lower bars should be as close to the same length as possible, and when you go to set it all up, do so at about 50% of your travel and try to keep them parralell to each other.
dssur   +1y
yep, 30 is goooood. Longer bars have less pinion angle change, if you do as adam suggests you wont have ANY.
My lowers are 26 inches, my tops are 29, and in 14" of travel the pinion angle does not change.
hopsing   +1y
I just did a Tundra, 33" inch lower bars , 30" wishbone, no pinion angle change throughout 13 inches of travel.
bdroppeddak   +1y
Edited: 2/25/2006 5:44:45 PM by bdroppeddak
that just 3 of 1245 interesting facts about rustys truck, read the other 1242 in my new tell-all book:
dssur   +1y
hhahahaha
I just peed a little in my pants.
kaoss   +1y
hhahahaha
I just peed a little in my pants. me to , was he saving that just for the perfect moment?
truck action   +1y
Just finished my Tri 4-link( see photo's in Toyota section,Rear set up) uppers 25 1/2''/
lowers 19'',no pinion change through range,4 1/2'' to 12'',front mounts in the same plane!!
dragginbagged   +1y
That is AWESOME Cris!!!!!!!!!!
bdroppeddak   +1y
wayne, you're next on the list when another boring, rainy saturday comes up!! just let me catch a topic to exercise my photoshop skills on......
