moving clutch master cylinder/brake booster? help??
royaltz2001@aol.com's avatar
tenagator's avatar
tenagator
ok so i z'd the frame tolday still got soem welding to do but i put a stock wheel under the truck as u can see in my pics and the clutch cylinder is very close and i havnet body dropped yet. i will be running 215 35 18 body dropping 2.5 inch and already z'd 3/4 of a inch.so what are my options? i knwo i can move the clutch cylinder up or back intot he fire wall more, but how the hell do i do this? where to start? what to lengthn, shorten? its kinda confusind under the dash area. if anyway can help post some pics or soemthing so i can see what im in for. i dont knwo if ill have to move the brake booster also i got KW uppers and lowers and using stock spindles.maybe i wont have to move it? thanks for any pics and suggestions.
GFreeman's avatar
GFreeman
i dunno if this helps, but if you need a better pic let me know and i can take some.
time1's avatar
time1
You WILL be moving it mike. I put mine on the floor and made it go thru the firewall right next to the frame rail.
tenagator's avatar
tenagator
uhhhh how the hell do u do that? lol sounds like its hard to do??
tenagator's avatar
tenagator
Edited: 3/8/2006 4:13:58 PM by tenagator
yea idf u can maybe under the dashs o i see what u did under there???
time1's avatar
time1
It wasnt that hard, i showed you some pics. The only downfall is that the clutch pedal is going to be alot stiffer. If i keep my truck (thinkin about sellin) i might go with a Wilwood clutch pedal. I can take some pics of it again if you want.
tenagator's avatar
tenagator
umm u may have showed me pics i forget? maybe u did ill check to see if i saved em. isnt that wilwood pedal the one that has the master cylinder on it??
time1's avatar
time1
Yea the wilwood ones are nice but PRICEY
tenagator's avatar
tenagator
bump
come onnnn need some pics!!!!!!!!!
TwistedMinis's avatar
TwistedMinis
I'd like to see those pics too Tim. I'm getting close to moving mine.
