Dodge Trucks \  Rear setup for a dakota
Dodge Trucks Make Specific
views 499
replies 8
following 7
95FullSiZE   +1y
Edited: 3/14/2006 7:41:08 PM by 95FullSiZE
Okay what exactly needs to be done to get get the rear of a dakota on the ground? I was thinkin shorten axel or can u get a set of 18's with a diff. backspacing to clear the fenders? is so what BS is needed? Also Just a regualr Suicidedoors notch or something special?
Center Stage   +1y
you can go a ton of different ways but doing a parallel 4 link an simple notch an over the axle setup is a very simple way to get it down, an as for the rear end, i narrowed mine so i could tuck 20s but its your call there cause you definently can also just have some wheels made or something to tuck , shortening the rear end may end up being cheaper for ya though.
An if you have any other ?'s just let me know an i'll help as best i can.
shoot me a email if you want
info@centerstagecustoms.com
later manJimmy - Center Stage Customs
95FullSiZE   +1y
Thanks man can u weld to the differntial. cause i know on my fullsize cehvrolet i was forced to do the parallel 4-link cause my diff. was cast. Also will the stock wheels with smaller tires tuck?
Center Stage   +1y
well you did buy the link from me
but no the dakota has a cast iron differential so if you wanna run the stock gas tank you gotta do a parallel
and ya you can tuck stocks with smaller tires
95FullSiZE   +1y
yeah i got the link off ya... U sell spindles cause im fixing to buy a set cause im bagging my front after lay'd out at the park...The link was awesome tho its all done up and looks great. and thanks for the info on the Dak ill give my buddy the info and see how he wants to go with it.
Center Stage   +1y
ya for sure we can get you a set of spindels, shoot me a email an let me know detail
sales@centerstagecustoms.com
and glad u like the link
fatheadjames   +1y
Got a narrowed rearend out of my 99 dakota for sale if your interested.
bdroppeddak   +1y
Edited: 3/15/2006 10:46:30 AM by bdroppeddak
check out d4k0t4 s profile, i narrowed his rear end 5", and the front 3 3/4", it has a wishbone setup on it with the stock gastank location.... i think theres a pic in my scoop of his rear setup....
misinlinc   +1y
im runnin 20 x 8.5 with a +40 on my dak and they tuck hard with a stock rearend but i flaired the fenders out bout a inch on each side for safe measure
