periportfd
Originally posted by bdroppeddak
they are not designed to work at a 0 degree working angle, you can have your pinion angle on the rear end at 0 and your tranny at 0, but if your ride height allows your driveshaft to have a 3 degree angle, you are good, because that gives you a 3 degree working angle at each joint. you should have the joints equally opposite to be balanced. but im sure im not completely right on that, do a search and check out some of the other pinion angle threads, andy on here has given some nice help previously.
Sounds good to me. George you can run either uppers or lowers triangulated.
