dssur
Originally posted by im2lo4ya
if you're disconnecting the line from the fuel pump and hooking it directly to the carb,
there is no carb in an EFI system. Thats why the title of the thread is EFI conversion tip.
Like Jim says, the return line exists on both carbureted and EFI systems, and neither is high pressure. The RX7 in tank pump also has a return. If you switchover to EFI, you dont need any part of the factory mechanica pump any longer. You can disconnect it and leave it on the cylinder head with no ill effects, it is not chain or sprocket driven, only a flapper that rides on an eccentric on the factory cam; or you can remove it and make a block off plate.
Sorry for the confusion.
