Page 1 of 3
Wheel Questions \  damnit, I need help PLEASE, i tried every thing.
Wheel Questions Q & A
views 453
replies 21
following 15
BLACKMAGICON24S   +1y
I cant seem to clean the brake dust out of the Sattin in my 'Intro=Rockman" wheels.
I have used soap & water, I have used paint thinner, windex, i dont know what else to do. please help. i need to clean them out.
BLACKMAGICON24S   +1y
anyone else have these rims or any ideas??? i was thinking maby i should just powder coat the sattin. any thoughts?
munk3yx   +1y
a heavily diluted acid type shit
A wrk in progss   +1y
wheel acid? if thier chrome dont let it sit on em too long. if you can get a hold of a pressure washer rinse the wheel acid off with one, works wonders...
BLACKMAGICON24S   +1y
they are billit aluminum, will wheel acid work on them to get the brake dust out of the satin???
A wrk in progss   +1y
i'm not 100% positive on that one, i wanna say yes, if you do use it then only let it sit on your wheels for prob 4-6 seconds max. But like i said try using a pressure washer to spray off the wheel acid.
BodyDragginGMC   +1y
DO NOT put acid on your wheels. I've seen too many people ruin wheels like that. Your best bet is some good ol' elbo grease.
A wrk in progss   +1y
wheel acid is harmless if used properly... i use to detail for a livin, and yes i have had my fuckups on wheels, but i have learned, if its diluted enough you wont have anything to worry about.
BLACKMAGICON24S   +1y
ok, so dont put acid on my wheels? ill try pressure washing my wheels first, then im guessing the next thing to do is send the wheels to a wheel polisher.
dubrocker04   +1y
do not use acid. there is a big difference between "used to do it for a living" and "just using it this once".
try some polish and a power ball.
