Interior \  the floor? ouch
the floor? ouch
Interior Q & A
views 464
replies 9
following 7
j-bird   +1y
well this weekend i pulled up the carpet on my Astro and noticed it's a little rusty! whats a good way to get rid of it and seal it up from rusting again! any sanding required?>
no1lowr   +1y
cut it out and make a new sheetmetal floor
918Designs   +1y
As long as its just surface rust and not rotted, you can clean it up hit it with some sand paper or scotch brite pads and put some POR15 on it.
j-bird   +1y
POR15? whats that and where do i get some? lol....it's not rotted!
travis98s10   +1y
As long as a piece of the floor is still there HIGH BUILD will take care of it
bodydropped85   +1y
werd check your local paint store, por 15 is the SHIT.
cruisinlowS10   +1y
Por15 will work great if its just surface rust and not rusted through. www.por15.com and you can get it on ebay too
j-bird   +1y
ok,so once i take care of the floor problom where is a good place to get the heat foam for under the carpet? and is there anything else i can put under the carpet to reduce the noise?>
no1lowr   +1y
dynamat or go the your local upholstery shopand get some heat foam.
cruisinlowS10   +1y
or go to your local junkyard and pull some of the heat foam stuff out of a wrecked car it would be much cheaper. try to find a high end car to pull it out of.
