down to bare metal; few questions for next step
henson.tony@gmail.com's avatar
Iownissan's avatar
Iownissan
well the paint on my truck was a little oxidized so i figured it might come back through when i paint it. well i decided to take it down to bare metal just to make that nothing like that will happen. here are my questions
what type of primer should i use?
should i do the body work on the bare metal or over the primer?
what is the best way to make sure that all the body work is perfect?
cruisinlowS10
do your body work on bare metal. next spray an etching primer, then regular primer
cruisinlowS10
i refer you to this thread. pay attention to posts # 2 and # 3
Iownissan's avatar
Iownissan
thank you kind sir. your generosity is greatly appreciated.
cruisinlowS10
no problemo
crippled4life
hes right also to get it straight run a guide coat over ur bondo to find your high and low spots than prime and block wet400
Iownissan's avatar
Iownissan
okay so here is my plan of attack:
-strip to bare metal
-apply body filler and sand with 80 then finish with 180
-spray the whole truck with an etching primer
-then spray with a urethane primer 2-3 coats
-spray a rattle can paint for a guide coat
-block the car with 180
-then reprime 1 coat of eurathane primer and sand with 400-600
-finally use a good urethane sealer 1 coat.
look okay to you guys?
2fknlowforu
i didn't think its good to spray etching primer over filler spots, just cause of the acid, i guess i was wrong
crippled4life
i wouldn't use the etching just a good epoxy for the bare spots and then 2k high build the rest
