Chevy/GMC Trucks \  Radio help
Radio help
views 311
replies 13
following 8
Wakeboard03S10   +1y
I have a 96 Tahoe LT and I bought it to use the 4x4 for something and do a little off roading but the stupid radio cuts out all the time. Its the stock tape deck radio with the cd player at the bottom of the dash. I bought a new cd player and installed it and it turned on said it was playing and no sound comes out. The stock radio dose the same of no sound comeing out and then it might scream for a min and then cut out again. what is the cause of the problem....rember both stock and after market radios do not work.
ShakinPlates   +1y
Several things to check for:
-conditiion of harness wires
-connection of wires to harness
You are shorting out or loosing connection somewhere... its just a matter of tracking it down
splashed   +1y
if it has tweeters it might have factory amp if it has a factory amp its pretty easy to bypass
Wakeboard03S10   +1y
it dose have the tweeters and the facroty amp. but I dont know where the factory amp is? the wireing harness looks good and seems to be connected. how do i bypass the factory amp?
Twisted Galant   +1y
The factory amp is under the drivers seat. It only runs the rear door speakers. U can bypass it. its junk anyways. Make sure you dont have any blown speakers as well. They will cause the radio to go into protect and wont play anything.
splashed   +1y
if its not under the seat its behind the glove box they are standard gm colors for the speakers
Wakeboard03S10   +1y
hum good to know. I will check it out tomorrow gives me some point to start.
splashed   +1y
if you need anything else email me and ill help
splashed28@yahoo.com
Wakeboard03S10   +1y
is the factory amp small and sliver? and whats the best way to bypass it.
mtm   +1y
i had the same problem with my ranger, upon examination of the wiring harness i noticed one of the wires were bare and was shorting out against a piece of metal behind the dash. New wire and now it works perfect
