Audio/Video \  having problems
having problems
Audio/Video Q & A
views 344
replies 16
following 9
draggin87yota   +1y
ok my system was wrkin fine till like 3 days ago wen in the mornin the amp wouldnt turn on so i didnt have any bass,wen i turned the car on the red light on the amp (which sez "protect")turns on for like 5 sec then turns off.i have no clu why this is happening usually i can figure it out but this time everything seems to be in it place so im completely lost,plz some1 help.
83dawg   +1y
unhook the subs from the amp and see if the amp stays in protect-could be a sub causing the problem
SiLveRProJecT   +1y
Edited: 5/4/2006 2:18:05 PM by SiLveRProJecT
well, what kind of amp is it...Some amps turns on the "protect" LED on intial load, and the only other time is when there is an overload. ANYHOW, i agree with "bigjdub"...Also you might wanna disco the rca's so all you have is power going to it and start there.....
ShakinPlates   +1y
blown fuse or a short somewhere
draggin87yota   +1y
well i tried everything,and still the same prob.i checked for short anywhere same thing happens.i noticed that wen i connected the power to the amp it usually makes sum kinda spark or sumthin and this time it doesnt do anything.so i dont know im gunna check out the amp to c if thats the problem.any other suggestions?
msturg   +1y
make sure you have a good connection on the ground, perhaps it came loose.
granth   +1y
try a different pair of RCA's
draggin87yota   +1y
ya i might try diff rca's.my ground it fine i checked it out,hopefully its my rca's.
draggin87yota   +1y
well i tried diff rca's that didnt fix it.but i did find out that it does the same thing with or w/o the power chord connected to it.can that be the prob?cuz i checked the fuse up front and it had a lil moisture.so i dried it out and im gunna try it again later.
granth   +1y
so, ur amp gets power without your power cable?
