Air Ride Suspensions \  MOUNTING 450C UPSIDE DOWN
Air Ride Suspensions Q & A
views 293
replies 15
following 15
corey0814   +1y
I was wondering if there would be any negative effects by mounting my 450c
Rigo   +1y
i had mine mounted side ways... like up and down ... with the head up and it kinda wore out faster.... may have been from bad mounting though ...
TC29720   +1y
We have mounted them upside down a couple of times and have never had any problems. I have heard of some people having a problem with it, but I don't know if they really knew if that was the case or not
nut   +1y
if you mount it upside down all the oil will run to the top of the piston and wont circulate like its supposed to through the bottom end, it'll burn it up
ir8st8   +1y
I HAD MINE MOUNTED UPSIDEDOWN OUTSIDE UNDER MY BED IN THE ELEMENT FOR 4 YRS... NOT 1 PROBLEM
corey0814   +1y
wow, 4 responses...2 good, 2 bad. i emailed viair directly with no response (it's only been 2 days though) thanks to you who offered assistance, but i'll wait & see either viair's response or wait for better than 50-50 chances ...but thanks again to allcorey
1lowrado   +1y
I emailed them the same question about my 380. they said no for upside down. But vertical like on a frame rail would be ok
mikewendt   +1y
My 2 450's have been upside down for 5 years and there still pumping great
dragn168   +1y
Edited: 5/16/2006 4:10:10 PM by dragn168
Edited: 5/16/2006 4:09:02 PM by dragn168
you could just make a drop down bracket that holds it lower than the frame but still right side up that would be what im doing for my frame or you could pick this up from grunionfabrication.com for 50 bucks
low mazda   +1y
hit up lance martz... scinfernal on here. he is now working for Viair.. he might could find you an answer..
