granth
Im looking to use an S10 clip because it has all the aftermarket I need, once I find out if its wide enough with the stock crossmember, i will be looking for a first gen clip, if not just a blazer clip. Do they differ much between the first gens of each? I know the spindles may be different.What I want to know is if I will get enough lift with 22's or 24's if i go under axle, or should i just notch the frame right before the axle. Reason I am looking at under axle and bending it upwards after the axle for the fuel cell is, I need all the room for my system as possible. Its a regular cab and i plan on going blow through. What are guys opinions? When I mock up under axle, I have to find right height correct, before doing the back suspension setup, for link bars and all, same with normal backhalf? Any help is appreciated.
