Ford Trucks \  Ranger wont stay running
Ford Trucks Make Specific
views 270
replies 14
following 9
94ranger   +1y
Hey guys, ive got a 94 2.3 and its acting a little wierd. Couple weeks ago, it died, and has been doing so ever since. Ill be driving when this happens, mostly coming up to a stop in neutral with clutch pushed in. Starts right back up every time, but just quietly dies, like i turned the key off while rolling. The guys on RPS said check maf by disconnecting it to see if it will run ok. It didnt even make it out of the driveway, lol. Im thinking it may have something to do with my ignition because a couple months ago something caused it to not want to start, thought it was the clutch switched, tried to bypass it, and still didnt work. Right now ive got an ignition button wired up to the starter solinoid. Anyone have an idea of what could be happening? Sorry for the long post too!!! I just dont want to hear the dealership or any other repair shop wine to me that my intake bolts are causing the problem, lol. Its happened before!!! Thanks again guys!!!!
jetts   +1y
kinda sounds what my car was doing, it happened to be the ignition switch.
94ranger   +1y
Ive been thinking thats what it could be, wow, this will be the third one replaced!!!
bodydropped85   +1y
disconnecting it will cause it to stall, sounds like an iac jon.
94ranger   +1y
idle air control right james? it does it while in gear too, was goin 70 on 85 south and it died!!!
bodydropped85   +1y
hmm, its possilbe it could be an ignition swtich. not sure tho. yea idle air control, take it off and clean it w/ some brake cleaner adn then put itback on see if it helps.
94ranger   +1y
Edited: 5/23/2006 11:26:36 PM by 94ranger
stupid question, but where is it at under the hood? Haynes manual is garbage, lol
Nevermind, found it
jetmodifydranger   +1y
Hey man my cat was clogged up and it did that junk to me a few years back. So if nothing else works you might wanna try that too.
mr mufakka   +1y
I've had a problem similar to that but it was caused my the Superchip coming lose from the computer.
94ranger   +1y
Thanks guys again for the help, I cleaned the iac and maf and my rough idle is gone, and it runs right now! Still dies randomly, but nowhere near as bad, still gotta try the switch, which hopefully will take care of this.
