Mazda Trucks \  RX-7 IRS in a 89 b2200
Mazda Trucks Make Specific
views 2897
replies 16
following 15
Fazethree6661   +1y
What all is involved in putting in an IRS from an RX-7?? do you have to build a whole new back half or just mod the original Frame? I am new to this and any help will be good I Know its been done and been asked a number of time but please dont flame me on this... I am also planning on doing and RX7 motor as well... I am getting this stuff for a good price and I plan on starting it in the first of winter... Thanks in advance....If anyone has pictures that would be good too...
impulse   +1y
your gonna be building a back half...
stromad   +1y
its direct bolt in
GarrickArends   +1y
Originally posted by 2lowastro
its direct bolt in
hahahahahahahahahaha......
I have an engine if you want it... with mounts, ecu, wiring harness, brand new block and rotors, chrome cat/presilencer (header) and tranny. $1500 plus shipping...
The engine is NOT a bolt in, you will have a lot of modifications to get it in. For the rear end you will have to do a back half.
waylowwhitey   +1y
I had the motor, tranny, and rearend in my 88 b2200. It was all easy for me, because I built a whole new frame. I still got the rear for sale if any one wants it.
SinistarCustoms   +1y
I backhalved mine. Measure,Measure& Measure again.
jaredmxg   +1y
shorten driveshaft + new brake line. and you will need a flat head screw driver.
jcordova   +1y
When did they become "backhalved" what happened to "sub-frame"??? I guess its time to step out from under my rock......
slamdB   +1y
You don't have to build another subframe for the rear if you don't want to. Look at pics, get the rear-end under the truck and come up with some ideas. I hope you have a welder and a tape. When you're doing trick shit like that, there's no one way to do it.
Later
dssur   +1y
duct tape.
the RX rear is short enough to fit under a stock frame and still lay out if you c notch above the axles. How bad ass would that be to stockfloor a truck and keep a stock bed floor? Without even raising it for the body drop?
