Page 1 of 3
Audio/Video \  1ch or 2ch
1ch or 2ch
Audio/Video Q & A
views 728
replies 24
following 13
draggin87yota   +1y
ok my n my friend are arguing bout this,is it better to have a 1ch amp or a 2ch amp wen running (2) 12's.my subs are 1400w n the amp im lookin at is 2000w 1ch.he sed jus "splice" the wires,he sed that thats better than hookin the subs up to an 2ch amp,wat yall think?
00Rngr   +1y
personally id get the 2 ch and bridge it.
no1lowr   +1y
the mono amp is better imo, made for a sub.
draggin87yota   +1y
ya right now i got a 2ch with 2 subs,so im still undecided on wat to get,are they diff in sound quality or sumthin
rickster6924   +1y
Go with the class d 1 channel amp they were designed just 4 subs and they put less strain on ur electrical system 2 channel amp were designed 4 full range speakers and when using subs in a ported box u need a subsonic filter and only class d amps have them
03on22s   +1y
If your going more for SQ alot of guys run stereo amps "because thats how its recorded" , but the class D sub amps are more effecient with power so you'll see less headlight dimming and such.
draggin87yota   +1y
oooo ok kool,that answered my question im gunna go with the 1ch amp then.thanx yall
msturg   +1y
Edited: 7/19/2006 12:34:44 PM by msturg
is nobody going to ask you what ohms your subs are? that's what makes a huge difference in what amp you can run in comparison to what ohm it's stable at.
I guess I'll ask.
what ohms are your subs, and how many voice coils do they have?
2 single voice coil 4 Ohm subs are perfect for most mono block amps. 2 dual 4 ohm voice coil subs are better pushed by a 2 channel.
draggin87yota   +1y
its 4ohms w/ a 4 layer,long voice coil
msturg   +1y
don't know what the 4 layer really means, but what i'm gathering is that it's a single voice coil. There is only 1 positive and 1 negative terminal on the back of each sub correct?
