front bags hesitate to lift fast 200psi
14 following
IN
i navin it
Front Set Up: slam specialties re-6 1/2 single port, 1/2" hydarulic hose, 1/2" valves. Giving it 200psi, from being on the frame to hittin the up switch it kind of goes up then it really goes up. so it hesitates initially to go up. WTF is the prob. Can anyone help?
SlamedGMC
WE need more info, like type of truck or car, motor, what type of valves, whats the PSI rating on them, what type air are you using.
Low_SST's avatar
Low_SST
also how close are valves to the bag? the closer they are the faster.
wht01ranger's avatar
wht01ranger
the bags arent fully compressed when laid out.
CommonVan
could have trash in valve not letting it open instantly
sweeden's avatar
sweeden
it might be binding something up untill u get to a certaint point and then it pushes passed it
IN
i navin it
have 2000 gmc sierra, v6, runnig nitrogen, 250 psi vlaves, the rear has same set up and almost hops with 200psi. The valves have 5 feet of hydraulic hose between the bags and valves. the bags are not fully compressed with the wheels i have on it, but also switched to wheels cups are desinged for and same problem, so its not the bags being compressed.
DBLT8K's avatar
DBLT8K
why hydraulic host just out of curiousity?
91 drggn dime's avatar
91 drggn dime
i've had mine both, at the bag and at the tank, the difference would need to be in milliseconds, not really worth it being the cause of a problem.. i hope that doesnt sound smartassy
mitsu94's avatar
mitsu94
if ur bags arent fully compressed then the space left has to fill up b4 the truck will lift mine does that in the rear bcause i made it 2 lay 20s and have 17s on it
s10
last post by baha +1y
