cadi wheels
12 following
draggingtb@yahoo.com's avatar
cadi wheels
draggingtb's avatar
draggingtb
so i'm thinking about throwing some cadi wheels on my girls' truck when we get it back. i can't stand the wheels on it. anyone know where i can get some / have some you're trying to get rid of? and what do i need to make them fit?
FreakwitaFro's avatar
FreakwitaFro
isuzu hubs are hub centric so in order to get escalades to fit you'll need to grind down the tabs on the hubs. best way to do it is to pull the hubs, knock the wheels studs out and get to grinding. you'll have problems gettin your center caps to fit too but i haven't messed with that yet...im still rockin denalis without em.
LynBdyMini's avatar
LynBdyMini
ive got a set of 17in escalades and a set of 05 17in chevs i would like to sell. both sets have the center hole machined out so you dont have to grind on your hubs. the escas have new 205/40r17 tires that have less 2000miles on them. give me a offer.
FreakwitaFro
lol or you could to that...have all 4 of your wheels machined to fit.
draggingtb's avatar
draggingtb
ok, thanks guys. sent you a pm curtis
h2omelon(nick)'s avatar
h2omelon(nick)
you can run the center caps if you use a 1/4 inch spacer. you will need lug nuts that have a shank on them that goes through the hole in the wheel so you can get enough threads to hold it on safely.
draggingtb's avatar
draggingtb
i'll need a spacer if they're machined too?
baggedpupon22s
I HAD TO MACHINE THE CENTER OUT BUT I DIDN'T HAVE TO USE SPACERS TO CLEAR THE WHEEL BEARING.ALSO COULDN'T YOU JUST USE A BIG ENOUGH SPACER TO CLEAR THE HUB AND THE WHEEL BEARING?
LynBdyMini's avatar
LynBdyMini
you do not have to run spacers, if you run spacers they will not tuck. gm wheels are so close to bed sides and fenders already if you run spacers they will not tuck.
slamsuzu
Edited: 9/5/2006 12:21:59 PM by dedicatedccvp
I Dont have spacers on mine.
I did grind the hubs back like listed above. Thats the only way to make the wheels fit. Make sure that when you grind them back that each nub is equally grinded or your wheel will wobble. You can do it with a grinder but the best way is to have it machined.......mine is done with a grinder because im to pour to have it machined. It worked fine for me. Let me know if you need any help or pics...
Oh yeah, I have amigo fenders on the front of my truck so I can tuck my wheels, you might not be able to tuck with stock fenders.
Related Discussions in Isuzu
