how do make an air cylinder suck the wheel up
lowtaco114@gmail.com's avatar
lowtaco114's avatar
lowtaco114
I have a set of cylinder and I'm pretty sure that if I get another valve, I can make the wheel suck up. Is this right?
tukn18saccord's avatar
tukn18saccord
if you have 2 port cylinder you will need a total of 16 valves. one set for top the othe for the bottom and wire them opposite from each other down to up , up to down
1 LoWfUKn RaM's avatar
1 LoWfUKn RaM
16? noo 12 valves yes
lowtaco114's avatar
lowtaco114
so you mean you need an extra 2 valves per corner? And I should use the other port on the side of the cylinder?
lowtaco114's avatar
lowtaco114
1 LoWfUKn RaM
cylinder should have a port on the bottom of it thats were the other 2 valves come in to pplace u can only do the rears front is to heavy to do so yes u need 4 valves per side on the rear but u need to wire then so when u trying to lift up the bottom valve anint close and wont let the air thru so u need to figuere out some crazy wireing there
lowtaco114's avatar
lowtaco114
you da man, thanks
1 LoWfUKn RaM
do u get me.. i suk at explaning
lowtaco114's avatar
lowtaco114
I got ya. It makes so much sense. I just needed a kick in the ass. The bottom port is essentially the same as the top port. You install a fill and dump valve and it acts the same as the other set of valves, it just pushes and lift the wheel up.
1 LoWfUKn RaM
yupp u got it
s10
last post by baha +1y
