where are the damn door pins
11 following
tuckinturbo
i have a 2000 mazda b2500 (same as a ranger). i have only owned old school mazdas and toyotas in the past so i am unfamiliar with alot of things on this truck. my problem is alot of times my interior light wont go out and my "door ajar" warning light is always on too. but i wanted to start by checking the wiring at the door pins but i cant find them on this truck, some one help me out. thanks.
biguglywagon
YOUR TRUCK DOESNT HAVE NORMAL DOOR PINS. THE PIN IS PART OF THE STIKER ASSEMBLY.
tuckinturbo
does anyone have any suggestions on how to go about fixing this, did anyone else have similar problems to this?
mtm's avatar
mtm
good luck with that man this is a common problem in rangers so i'm guessing its the same with the mazda. Mine dinged and the light stayed on for 50 miles one time. Drove me fucking insane. Ended up finding the door dinger (behind the stereo) and ripped it out and destroyed it. Never had a problem since.
fatboysS1O's avatar
fatboysS1O
thats crazy. my 95 ranger did that way back in the day. it ding every once in a while. sometimes it ding for a while,sometimes it ding once and quit. never figured it out but know now.
thatsmydawg's avatar
thatsmydawg
its prolly the door switch is bad sometimes its mountsed on the door latch inside the door or its mounted in the cab on the bottom where the door hits the body
ricky@3rdshift
spray some wd-40 inside the latch area on the doors. That should help unstick it "usually the problem" if not I believe you have to replace it on the latch assembly if you can get it seperate.
thatsmydawg
ya most likely if the switch is part of the door you have to get the whole latch and sometimes its not cheap
bodydropped85's avatar
bodydropped85
go to the dealer and get some new switches, i think there 7 bux apiece.
tealrangerpmp
Edited: 9/27/2006 11:09:16 PM by tealrangerpmp
it is from the grease buildup in the door latch lithium grease works better stays longer really the only fix
