Ford Trucks \  how much harder would it be..
Ford Trucks Make Specific
views 381
replies 15
following 7
fuller   +1y
to build a frame for something you dont have the stock frame for? why do i ask? well i'm goin to look at a 94 4dr explorer thats just the body firewall back and nothing else, can get it for like 25 bucks so i might hop on it. 1st step would obviously be to get some sort of front suspension which will be a toyota clip. then from there i guess alot of measuring and making sure i get the rails put in the right spot so i can get body mounts in the right spot and so on. does any1 have any tips or ideas that would make this seem easier for me? i know i can do it, its not a matter of lack of skill, just trying to get as many ideas as i can to see if its really worth gettin myself into. thanks
bodydropped85   +1y
yes! body mounts wont be hard. just so you know you have to relocate the rear body that is in front of the axle from the inside of the frame to the outside.
BK2LIFE   +1y
easy. you gunna lift it or lower it? if your gettin a yota clip, im geussin your stok floorin it.. easy to do. many projects i build are exactly how you described. you got a body, now make it how you want it.
im juts hopin you have sam fabb skilz, and welding skilz
bodydropped85   +1y
the good thing about an explorer is you dont need more then a bout a 2 in stock floor to lay rockers. i did my buddies back in 03.
fuller   +1y
Edited: 10/3/2006 11:38:20 AM by Fuller
thanks fellas..and yes, this will be goin down to the rockers...James, what do u mean about the relocating stuff? and will it be an issue to keep the second row seat?
bodydropped85   +1y
a 4 link yes, youll have to raise the floor up for it. i had to move the body mounts from the inside to the outside of the frame.
slammedxonair   +1y
probably need to tunnel for the upper 4 link bars i did on mine
John Nissan   +1y
we took the cab off my truck and tossed all the factory frame, suspension, fuel in the garbage. The garbage man was pissed that day.... set your front and rear suspention to center with the truck laid out and build to that.
fuller   +1y
so i wont be able to keep the seat? or what can i do to keep it cuz i would really like to be able to
bodydropped85   +1y
you could prob prob take the mounts off the seat and mount it to the floor that your raised up.there is a good foot below that rear seat.
