stckflr with beams?
13 following
stckflr with beams?
tbmx86
Has anyone ever done a stockfloor with the beams? I always hear of people doing a yota clip. But I cantseem to find one, and I dont really want to have to change the steering and all that shit up. Besides, I like my beams. I wanted to z it then lower the motor down an inch or two to compensate. Any thoughts?
doordraggintaco
I HAVE ONE I WILL SELL.ALSO HAVE A REAR YOTA AXLE TO GO WITH IT.
Iownissan's avatar
Iownissan
you have a 97 ranger. it doesnt need z'd. and yes, there are rangers stock floored with i-beams
tbmx86
im stockflooring it. so im cutting about 2 or 3 inches off the bottom framerails and reboxing them in. so yes, it does need to be z'd cause my truck is already laying frame and the beams arent goin anylower
msturg's avatar
msturg
That's not the way most people do a stockfloor, so your Z question is sort of out of the norm. If you did it the way you are talking, I'm guessing you would more than likely need to take 3" out of the bottom of the frame and then Z it. You prolly won't have to drop your motor but it might help for the extra clearance.
One question though, if you are going to go thru all the trouble of pulling your cab and such, why not do a more reliable stock floor? By using 2x3x1/4" all the way back from the factory clip?
Iownissan's avatar
Iownissan
you must have no idea what a Z is
N
NaviGangsta
he wants to cut the bottome of the frame off, so yes it does need Z'd .. he does know what a Z is apparently.
you can keep the stock position of the cab mounts, and not have to b/d the bed if u do it that way
BAGD RANGER's avatar
BAGD RANGER
YES IT DOES NEED TO BE Z'D --- IF U HAVE THE SKILL -- IT IS EASIER TO JUST BUILD A FRAME FROM THE Z ON BACK !!!
tbmx86
thank you navi gangsta. And lownissan, if you cant understand what im talking about then it is you who does not know what a z is. And the reason Im just going to modify the stock framerails is so I dont have to make new cab mounts, and dont have to build a complete custom frame. I know what Im capable of, and to modify my frame already in place is one thing, but to build a complete custom frame Im not so sure of.
Iownissan's avatar
Iownissan
ahhhh i get ya now and what your attempting to do. i dont think its a good way to do it though personally.
