Page 1 of 3
Audio/Video \  new amp need install help
Audio/Video Q & A
views 1386
replies 29
following 15
gary63   +1y
i just ordered a crunch 1200 watt 2 channel amp and i know nothing basicly about wiring up stuff i have 2 10'' alpine type-r's and they are 2 ohm dvc so if anyone could fill me in I would be greatful and maybe a diagram if possible
wallacejr29   +1y
try this link!! it might help. I been doin installs for years, its very easy!
http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/amplifier_installation_guide.html
lownoma99   +1y
yea...crutchfield has all the wiring info broken down for what kinda subs ur running and what kinda amp and how to wire the subs up into the amp. good luck with it man
rickster6924   +1y
u need a 2 ohm class d amp because that amp is 2ohms per channel or 4ohms bridge ur subs r dual 2ohm so u can only hook them up at either 1ohm or 4ohm per channel! Or 0.5ohms and 2ohms bridge
ShakinPlates   +1y
He doesnt need a class D. What are you talking about??? Just read crutchfields deal.
rickster6924   +1y
why don't u tell me why he don't need a class d amp
dkno   +1y
caraudiomag.com, and crutchfield.com has the diagrams and pics for you 2 c
rickster6924   +1y
the crunch amp is 2ohm stable per channel his subs r dual 2ohm. They can only be wire up at 1ohm or 4ohm per sub per channel or the amp can be bridge at 4ohms but the 2 subs wired together can only be wired at 0.5ohms or 2ohms. So which part of this do u not understand
rickster6924   +1y
He can wire the subs at 4ohms per channel but then he will be getting only about half the power
ShakinPlates   +1y
why don't u tell me why he don't need a class d ampClasses of amps are related to the circuitry and how the power is switched and distributed throughout the amp. In no way is it manditory to run a certain class amp....
