weird ratting noise from catalytic convertor i think
13 following
xdragonopticalx@aol.com's avatar
CFL99SDIME's avatar
CFL99SDIME
ive had this noise from what sounds like pieces of my cat broken off inside ratting when im idling but now since its gotten colder it is about 50 times louder and i would really like to know what the hell it is so i can take care of itim thinking its the cati dont think it would be coming from the headersbut it deffinitally sounds like an exhaust thing and it has progressedlet me know if you have had something like this happen to yours i have a 99 s10 ext 2.2L
LiL bLaZe's avatar
LiL bLaZe
Well if it is coming from the cat, it's probably the honeycomb paper material inside broken loose. Take the cat off and break all of the guts out, then put it back on, it will have a cat, just with nothin in it
TwistedMinis's avatar
TwistedMinis
^ exactly.
CFL99SDIME's avatar
CFL99SDIME
should i just stick a pipe in there in push the shit out?
W
Wakeboard03S10
yea when you take it off just ram a pipe in it and let all that shit fall into a trash can..and belive me there is a ton of shit in there...
CFL99SDIME's avatar
CFL99SDIME
those bolts are rusted on like a bitch
i cant get them off without stripping them out
i tried letting them soak in penitrator
but to no avail
can i just cut the bolts if so
where could i pick up the new studs and bolts?
CFL99SDIME's avatar
CFL99SDIME
also if i punch the insides out wont it tell my o2 sensor that im running to rich?
SYCOTIK's avatar
SYCOTIK
yeah its the cat. my friend had the same thing happen a couple months ago with his s10. took it off and u can hear all the stuff rollin around when u shake it.
bdydrp97s10
yes, its your cat, samething happened with mine, it beat the shit out of the inside of it.. yes it will throw a check engine light because the O2 sensor will detect the engine running rich. as far as the bolts go to the hardware store and get some new ones, just make sure to put them in once then after the engine heats up re torque them because the heat will loosen them.
bodydropped85's avatar
bodydropped85
Edited: 11/19/2006 4:18:44 PM by bagged85
get a new converter. the rear o2 sensor will sense the motor running rich and lean it out thus probably burning a valve or worse over time.
