msturg
I'm doing my senior design on this sort of stuff. I'm telling you right now there really isn't too much you can do for the ranger arms that will help that greatly. The main problem that arises is the balljoint angle causing them to bind up. Other than that you have the obvious camber problems. Now if you extended the upper control arms with an adjustable set like byc, then that means your just going to get that much more positive camber.
for guys running big wheels the problem isn't just the camber and being able to ride low, they obviously also need to clear them. I think the suspension currently get a very good amount of lift but already has a lot of positive camber.
I have ideas on how to fix these problems, but if it means someone else taking the idea and turning a profit on it, I'll pass. Sorry.
