steering on body drop
laidiscrewu@yahoo.com's avatar
laidiscrewu's avatar
laidiscrewu
Was wondering if any one out there had a problem with the steering lining up on there body drop??I was gonna run a dubble knuckle.Is there a another way?The body drop is 4"
stopndrop
yeah byour definetly gonna have to run a nuckle set up with a heins joint or remount the steering column in a different spot.
tenfrontier's avatar
tenfrontier
I have the same problem. I was going to move the hole for the steering shaft up a couple of inches. But if there is another way to do it, I would like to know how. My Frontier is body dropped 4" as well.
Brill's avatar
Brill
Just cut your firewall.. and do the body drop like normal... then cut a circle around your steering column.. then cut out a space however much your body drop is above the circle you cut out aroudn your column..
That way when the body falls to the floor, the column will stay relativley close to the stock location.. and then you shouldnt need to modify it much.
F
FlawlessFab
by doing that way dusty said you will more then likely have to modify your stock dash if you are re using it....if you have a tilt column you might be able to get away with not modding your dash....but not 100%
Brill's avatar
Brill
Yeah, forgot to mention the dash.. =(
If you do it that way, like flawless said.. you will need to rebuild or modify the mount that holds the column to the underdash support.. That all depends on how much of a body drop you are doing..
or
Ditch the stock dash... go all sheet metal!!
laidiscrewu
cool.Im gona have to go with the dubble nuckle Thanks
BK2LIFE's avatar
BK2LIFE
easiest way is to leave your column in stock place, and modify the bottom half. use an extra u-joint or 2, and itll work fine. look up sterring kits from jegs.com or flamingriver.com, youll see how they do it.
deflatd
my steering was fine with a 3" bd.
tenfrontier
Edited: 11/27/2006 8:05:16 AM by tenfrontier
Would this work fine? www.flamingriver.com/index.cfm/page/ptype=results/Category_ID=115/home_id=82/mode=cat/cat115.htm
