Page 1 of 4
Air Ride Suspensions \  best setup for hitting sides
Air Ride Suspensions Q & A
views 507
replies 38
following 22
CFL99SDIME   +1y
wondering what the best setup is if want to hit alot of sidesif i 4 linked it i wouldnt think i would be able to hit sides
Iownissan   +1y
get the SD super lift 4 link with super pivot bushings
no1lowr   +1y
anything with more than 2 links and 8 valves
CFL99SDIME   +1y
i would think 4 link or 3 link would keep the axle from moving up on one side and down on the other
could i hit sides without super pivots or is it a must?
Master Fabber   +1y
sounds like you need to get a street bike, do 100 and lay it over on its side. That would be straight clowin
CFL99SDIME   +1y
that has nothing to do with hitting sides in a truck
holcombe347   +1y
thats what the super pivots are for. they go on the end of the link bars, they allow the bars to 'twist' at the pivot. letting you hit side to side. if you dont put those pivots in or hyme joints in you'll twist and bend your fourlink.
Master Fabber   +1y
OMG I was kidding hitting sides is gay. If you dont get the first one how about jump off a cliff and land on your side?
91 drggn dime   +1y
it wont twist your bar unless you have shitty bars.
the regular rubber bushing will bind and not let you hit mad sides. You can still hit sides with them. You NEVER hit sides in life but maybe once, so setting a truck up to hit them, is gay.
olskoolpup   +1y
you can do bag over axle, and a wishbone 3 link. use super pivots on the 3 ends that connect to the axle, regular poly bushings on the 4 end that connect to the frame.
