Ford Trucks \  FIBER GLASS WORK
FIBER GLASS WORK
Ford Trucks Make Specific
views 350
replies 15
following 11
BIG SHAWN   +1y
HEY GUYS A LOT OF YOU HAVE YOUR DASH GLASSED AND DOORS AND PANNELS HOW MUCH DOES THAT COST AND HOW LONG DOES IT TAKE.I'VE GOT A QOUTE FROM DA GUYS WHO PAINTED MY TRUCK OF 1100 BUCKS, BUT THEY ARE USING PUDDY I HEARD ITS GOOD IF YOUR TRUCK IS NOT A DAILY DRIVER AND IT DOESN'T SIT IN DA SUN ALL DA TIME,AND I KNOW REAL GLASS IS DA WAY TO GO....SO IF YOU KNOW WHAT PRICE RANGE I SHOULD EXPECT AND THE TIME LENGHT IT WILL TAKE HOLLA ATCHA BRO!!!
hybrid showoff   +1y
what parts do u want gla$$ed? price will always vary depending on what you want built and how ellaberate the design.
BIG SHAWN   +1y
JUST DA WHOLE DASH, DOORS,AND PILLARS
jdauer02   +1y
if you want the "glassed" look without any modifications done to them you can sand them down to 2000, high build primer - sand again then paint.
FABLAB   +1y
Honestly that sounds a bit low to me. And I'm not a bodyman but I wouldn't want it done with puddy, I would go glass for sure, just sounds more durable.
BIG SHAWN   +1y
COOL THANKS GUYS
nyccustomizer   +1y
Does that kind of fiberglass work hold up to daily use? Ive seen alot of door panels that crack with use. I think it has to do with the vibrations and ppundings that they get from every day use.
FABLAB   +1y
If it's done right it should hold up for a long time if not forever.
hybrid showoff   +1y
gla$$ work most always uses body filler. whether gla$$ is laid depends on the person doing the work. see how something is built is with a wood framing setup with fleece wrapped over it to give it its shape, then fibergla$$ resin is brushed onto the fleece and let to cure. after thats done for door panels you dont NEED to have gla$$. kitty hair body filler is plenty strong enough. dashes are the same. now laying fibergla$$ will definately make the product a lot stronger and more durrable but is not always needed. sub enclosers are completely different. if multiple layers of gla$$ are not used the encloser will collapse.
tukn18saccord   +1y
ive always used the liquid glass and then go over it with light weight never had no problems
