Chevy/GMC Trucks \  fuel cell wireing
fuel cell wireing
views 641
replies 18
following 7
wez   +1y
so i finally did it i broke down and bought all the parts pumps fittings to put a fuel cell in my truck( 99 sonoma with the 2.2l) and ditch the gas tank that sits in my bed.... i got a polished fuel cell (summit part number RCI-2151AS) and a msd fuel pump (msd-2225) along with all the plumbing to take the fuel line from a 8AN to a 6AN both for my feed line and my return line..... the problem that i am facing now is that i dont know how to wire the danm thing..... can i just use the poser for the fuel pump from the stock wireing that would be really nice.... also i dont know how to hook up the sending unit for my gas gauge.... how do i do all of this and what wires do i use the pluming is easy its just all the electrical shit that gose with it..... any help i can get i would appreciate it...
thankswes
wez   +1y
any one
tcsxtremeison22s   +1y
just outta curiosity, what did all the parts cost you... im having problems with my factory fuel pump and tank and im considering switching to an aftermarket cell and pump...
wez   +1y
around 350 total got thefuel cwll from e-bay for like 175 a pump from summit for like 100 and fittings and hose was like another 100 but i got steel braid so you could probably save some money and get regular hose
wez   +1y
so what i am getting out of this is no one knows how to do this...
lowdyme   +1y
there should be 4 wires on your stock sending unit there will be 2 grounds and 2 powers you just have to extend 2 wires to the pump and 2 wires to the cell for the sending unit. to figure out which wires were what i cut one wire at a time and then turn the key and see if you hear the pump working and check the gauge. then the one that dont work is either the power or ground for that
wez   +1y
hum... thanks.... i havent really looked at the harness yet because i have been at work for the last 4 days but that is helpfull thanks alot
wez   +1y
Edited: 2/12/2007 10:58:31 PM by wez
ok so i broke into the wiring harness 2 night... there is 2 oranges that run into a green box where there is a 3 orange wire have not clue what this box is for (see attached pic) 2 grey wires one is thicker than the other one.... a green wire a purple wire and a black--- ground.... i wish some one could tell me witch ones to run to my fuel pump and witch ones to rund to my sending unit.....3 wires i know go to the sending unit.... i took a buch of pictures that i am posting below...... also when i turn the trck on i tryed to test the wires to see witch ones get power and none of them were getting power any ideas.... thanks for the help guys
wes
PICTURES
wez   +1y
also if i did not mention it when i put a test light on the wires i got nothing no power to any of them..... any one have an idea for that
lew
wez   +1y
someone out there has to know how to do this
