side skirts??
shavedgalant03@aol.com's avatar
side skirts??
shavedgalant03's avatar
shavedgalant03
i have a problem with my side skirts on my car. the problem is the side skirts hit the bottom of my door. any idea how to fix this problem?
shavedgalant03
anybody ??
jhoz's avatar
jhoz
maybe grind the bottom door edge, but dont take to much off, as the door skin will split away from the door! how bad is it rubbing? can you move the skirt down at all?
shavedmax
dont grind on the door. 1/16th of an inch and your skin will come loose and you'll need a door. shave down the side skirt if you can. i had that problem on my first max, i shaved down the urethane some, but it still hit. my new one is fiberglass and fits a little better
shavedgalant03
cant move the side skirt down and im going to mold it in its rubbing so bad that when shut the down the side skirt moves
lowdyme's avatar
lowdyme
yea i would grind the kit down a lil.
shavedgalant03
i grinding them down they still rub
BggdNBdyDrppdJunk's avatar
BggdNBdyDrppdJunk
are your doors sagging at all? can you adjust the hinge to raise them?
shavedgalant03
i dont think the doors are sagging and i dont know if they can be adjust cause i never took them off and thats how it came from the factory
shavedgalant03
any more ideas?
