Best way to shave a body line???
26 following
clenzer72
I need to shave the body line on my ranger and i've been told a few different ways that can do it. Use short Kitty hair glass and fill it, have sheet metal cut and weld it in, place welding wire in the center and weld that in.
What do you guys think???
TwistedMinis's avatar
TwistedMinis
I'd probably go for the sheetmetal route. Thats how I plan to shave the bodyline on my bed. But mines a little bigger. Still the same idea I would think, just on a smaller scale.
Severed701's avatar
Severed701
i wouldnt be afraid to fill small bodylines with something like dynaglass or the kevlar reinforced fibertech stuff..because really..by the time you weld that all shut and get it ground down its most likely gonna need a bunch of mud anyway...and as long as its prepped right you can get away with using a decent amount of filler without problems...put a straightedge on whatever your filling and see exactly how thick it will be..may not be as much as you think...
clenzer72
yeah, it's not that deep. and with so much welding and grinding to get it all warping would definately be a consern.
The only thing i'm hesitant about using the reinforced filler is that i'm afraid it will start cracking in 2 years and i'll have to do it all over, and repaint
mindlissmetalfab's avatar
mindlissmetalfab
weld
BaggedMazda87's avatar
BaggedMazda87
Yeah weld it man
As long as you don't move too fast you shouldn't have a problem with warping. Especially due to the fact it's on a stamped bodyline, not a flat pannel.
You could probably get away with just filler if you prepped it right. But if you weld it you KNOW it won't crack out, ever
BaggedMazda87
By the way your fucking truck is sick
I had to change my pants right after i opened the thread...
addicted
yeah....i would go ahead and take the time to weld it up, and like they said if done right it wont warp and you never have to worry about it cracking out.
wymplo94's avatar
wymplo94
I did it on my boy johns ranger been done shit for a few years now hasn't swelled or cracked at all I used the short stran glass by evercoat worked great sands easy..
brammerbull
I welded my body line on 1sr gen s10 and got to the beds all done one side was worped to hell and back! diffently take ur time! took me a week to weld both sides!
