holcombe347
i pulled the engine and trans out in my toyota a while back it was pretty easy... be sure to take pictures of EVERYTHING especially the complicated areas where you have vacume lines and such going. i labeled everything as well. my electrical connections were lettered and my vacume connections were numbered. it was pretty easy. although it was my first time doing it as well, it took me a few nights (only wrenching a couple hours a night alone) to get everything disconnected and labled checked and rechecked. it helps when you have two people there to pull it out and put it back in aswell. with my toyota ifound it easier to pull the motor with the tranny. but either way, im sure you'll be fine. after you get the motor out you'll think to yourself, wow...that wasnt as bad as i thought. lol good luck with everything.
