Body work and Paint \  Ideas On Painting 350 block
Body work and Paint Q & A
views 258
replies 14
following 13
brcoffey   +1y
what kind of ideas does anyone have on painting a 350 block and 350 turbo tranny what kind of stuff can i use to make it last?
keele   +1y
Just Base and Clear
creative concepts   +1y
base and clear can get hot and bubble.. they make a 2 stage engine enamel i believe.. if you dont know how to spray, they sell it in spray cans, take your time and apply it evenly and you cant tell.
LOWEST1   +1y
THE most important part is clean and prep!!! I Normal base/clear can last a long time.
Hc Daytona Dragger   +1y
krylon worked good on mine lol
granth   +1y
any paint can get hot and bubble. the simple fact that a motor shouldnt EVER get over 250 degrees, is enough safety that base/clear will work perfectly fine. Prime it first of course, as it is bare metal after fresh rebuild.
dragggn   +1y
yea i base cleared mine 6 years ago with no problems.. oil leaks can stain it though.
also por-15 makes an engine paint-- i havent used it, but if it works like there regular formula its bad ass stuff-- plus its self leveling, so if you use a little technique you could brush/roll/foam bruch it on, and you would never see brush marks..
brcoffey   +1y
the bad thing about base/clear is that on a motor clear starts turing yellow so im just seeing if anyone else has any ideas. what do u guys think about ceramic coating but dont know
bbt fab   +1y
prep with a scotch brite and lacquer thinner, etch or epoxy prime it and then you can single stage it or base clear it they will both hold up preperation is key though
vincer   +1y
clear turns yellow if you only put clear on it and no base!
