Air Ride Suspensions \  s10 4 link ?
s10 4 link ?
Air Ride Suspensions Q & A
views 499
replies 3
ohioratrodder   +1y
i am wanting to keep my stock gas tank on my 93 ext. cab s10 and would like to know if you think any of the s10 4 link kits(bolt on or weld on) that company sells are worth the time and or money? i sure they all will have pinion angle change because the bars are not the same length but if i can set it up at ride height i should be ok right? i have talk to most companies and steve over at cando seems like his 4 link would work the best for me because all 4 bars are adjustable and has the rear end bracket that use all 10 bolts. or do you think it would be better to do a 3 link with a panhard or watts link?thanksjason
mindlissmetalfab   +1y
Wishbone 3 link from SD is a good kit. Upper and lower bars are close to the same length so angle change is minimal. You relocate the spring hangers or else buy the kit with new ones and move them further back on the frame which keeps the lowers short to match the wishbone and prevents you from draggin through the bar ends.
Brill   +1y
Get the 3-link kit from SD.. I think it comes with a raised gastank x-member..
fatboysS1O   +1y
give www.gravity-werx.com a call and see what they can do for you.
