Pics of BYC toyota uppers and lowers
11 following
laynrkr@yahoo.com's avatar
LAYNRKR's avatar
LAYNRKR
Just got my set of BYC arms( yes I got fucked over too!)and I need to see some pics of the lower arms and how they are ran and installed. thanks for any help.
1lowrado's avatar
1lowrado
wow, they're actually still shipping? mike must be out on probation or something
olskoolpup
those were probably 1 of 25 sets that were "lost at UPS". maybe the only ones that really were.....
dssur's avatar
dssur
see what ryan thought of than no one else did is that you should try to buy BYC arms from someone besides mike white, that way they actually show up.
AVTekk's avatar
AVTekk
werd im totally confused as to how you just got em..
dssur's avatar
dssur
he bought a set from mike
they never came
fast forward a year and a half, he bought another set from a guy who bought a set from mike, and they came.
I'll let him eloborate on the rest.
corey0814's avatar
corey0814
they're not good pics & it's filthy, but it will give you an idea. you'll have to take a torch & melt out the lca bushings (this takes forever). then you take your air hammer & drive out the thin metal sleeve. it's super thin, but strong as hell. you can barely see the thing, but clean off all the dirt & you'll see it. any other questions, feel free to hit me up...good luck...
corey0814's avatar
corey0814
Edited: 4/27/2007 5:43:32 PM by corey0814
by the way, those are old pics & since then i've changed the lower shock mounts so they don't rub on the rim & my ground down frame spreader has been replaced by a tube setup. i also added a couple of gussets to the back of the mounting tubes to the bottom of the frame, but i'm not sure if that's totally necessary because they never felt like they were flexing, but it makes me sleep better at night knowing it's stronger & more stable before anyone starts hating..
corey0814's avatar
corey0814
forgot to throw you some pics of the uppers, although they're pretty self explanitory...
LAYNRKR's avatar
LAYNRKR
Thanks alot Corey, Did you basically just "eyeball" where the lower caster should be set, or did you just center the rodin the hole?
