Dodge Trucks \  Cranking
Cranking
Dodge Trucks Make Specific
views 541
replies 18
following 6
Deluxe_D100   +1y
Ok, well I am switching from a auto to a manual transmission. We are almost done, but it will not crank. We got the starter checked and it is good. Could it be anything from the column considering it's the same one minus the auto shifter? Any help would be greatly appreciated.
Deluxe_D100   +1y
92 dakota with the 3.9
gimp5561   +1y
did you change the harness? what all did you chance?
if the pcm does not see a signal from the neutral safty or that it is in park it will not start
Deluxe_D100   +1y
Edited: 5/13/2007 12:59:16 PM by BrandonSmith
Could anything from the stock column do with it?
Deluxe_D100   +1y
Bump
standardbyker88   +1y
i think the other guy person is right, hook up the neutral safety switch directly to ground, and it should work. its basically a switched ground setup. ground it and you should be good.
another option, put the key in on, foot on the clutch, out of gear. then have somebody cross the points on the starter relay.
Deluxe_D100   +1y
Edited: 5/13/2007 4:17:42 PM by BrandonSmith
Were is the neutral safety switch?
Deluxe_D100   +1y
bump
minitrukinranger   +1y
A switch that keeps you from starting your truck with an automatic tranny unless it is in the "park" position. Since you changed yours over, just find the wire to the swith and ground it.
Deluxe_D100   +1y
We grounded it but nothing. We turned the lights on and the wipers and tried to start it and the wipers stopped so we think the battery may be low.
