battery dying trying to find out why
15 following
pootus21@aol.com's avatar
simple-pleasurez's avatar
simple-pleasurez
i have no idea why my battery keeps dying. if i jump start it will run and keep running til i turn it off. about 5 minutes after i turn it off it will not start. anyone have a trick besides going thru and looking at every single wire to find a problem or is it better just to take it to a electrical place? i am stumped.
detached's avatar
detached
alternator
BB
bill brasky
probably your alternator, yes.
Start it up and take a wrench and put it to the back of the alternator if there is no magnetic pull then that will tell you it is not working.
Also, what kind of battery do you have? It could be a bad cell or something.
thelowerigo65
You need to "Load" test the battery. It sounds like it's a toasted battery. Any local Kragen, Pep Boys, etc.. can test it for you.
thelowerigo65
dirkbelt's avatar
dirkbelt
yea my girls ranger did that the other day and it was the battery,it had a dead cell from not puttin water in it and the battery was 5 years old
dragitpuzzy
NOT THE ALTERNATOR. If after jumping it will run until you turn in off, then it's running from the current made by the alternator. You need a new battery. While it's running go ahead and disconnect the battery. It should remian running. If so, replace the battery. No need to reed anymore posts. Try this and you'll be railing again soon as you shell out some coin for that new battery.
simple-pleasurez
i have put in another battery and it does the same thing.... i have also tried to disconnect the batt while it is running and it stays running like a champ.
CHOSN1's avatar
CHOSN1
Have you tried replacing your camshaft ...but seriously, what about connections. You said you tried another battery and it did the same thing and I'm guessing the alternator is good. Maybe clean the terminals or something
aerodeck
buy an optima, they last forever......
