22re turbo
12 following
22re turbo
lomofo85730
i am going to turbo my 22re, and im looking to build my own header. has anyone else done this or have any tips or pics?
prorida's avatar
prorida
are you trying to build your own manifold? my roomate has a 22reT in his mini, and i can get pics of a stock 22ret manifold if that will help?
TwistedMinis's avatar
TwistedMinis
22RETurbo.com
This guys got some custom manifolds, and everything else you will need to know.
lomofo85730
i was going to build a custom header, i have all the flanges like the one for the head, the turbo, and bov. i just wanted to see if anyone else has done this and had pics. btw the ones i saw to buy were way too much or looked like s**t so that is out of the question
siklife
this is all i've ever seen for a turbo kit, any cheaper or know where to buy one let me know =)
http://www.toyotacatalog.net/M1WebGear/ProductDetails.aspx?PartUniqueID=474DB8B1-F9C2-47F8-B30B-F1C3C8CE76D7
N
nicfit
Turbonetics makes a cast manifold for the trucks.
Part #30525 Toyota Pick Up, 81'-95' 22R 2.4L
SSM-Webmaster's avatar
SSM-Webmaster
check out reddevol's profile he's in my club and has a 93 yota with a 22re turbo'd and he works for honywell garret turbos he can help you out
onehightoyota's avatar
onehightoyota
i've turbo'd one before. if you plan on running it without an intercooler dont push over 6psi. get an external wastegate that you can change the spring in. if you intercool it, you can safely go up to 10psi and if you do a full piggyback for fuel and timing the stock motor can take as much as 15psi and still be safe and dependable. go to LCengineering.com. you will need to spend lots of money there. you need injectors, fuel pump, adjustable FPR, dont forget the colder plugs and a piggyback for the fuel and timing. URDusa.com is the place to check. they have lots of toyota engine controllers. unles you wanna get crazy and build a low compression motor and push some serious boost, then you will need to go full standalone and swap your mass air to speed density. tryint to turbo a naturally aspirated engine is gonna have its querks. promise you it will be a headache but if you ever stick through it and get it all right its fun as hell. i built a 92 turbo's and an 03 turbo'd and they are so much fun but cost more than you can ever imagine. here is a picture of my manifold and my setup
onehightoyota
MODS???? how come my pix wont post?
Uncle Fester's avatar
Uncle Fester
Edited: 7/12/2007 8:30:29 AM by SSM-Uncle Fester
Add the html tags around it to post them.
Also make sure the link is pointing to a image and not a html file.
