anybody runnin 3 12"s???????????
15 following
thebrantleys3@gmail.com's avatar
LndRanger86's avatar
LndRanger86
just wandering if anyone is running 3 12's in there ride? if so how is it wired and any pro's / con's to that choice of setup ? any pics of custom setups with that configuration would be great.
IB2LOUD's avatar
IB2LOUD
I had 3 12s in the back of my Scion tC, it sounded great to me
datboychevy
yeah but how would you wire an odd number of subs to 1 amp. does the ohmage have to be a whole number?
datboychevy
wymplo94's avatar
wymplo94
the12volt.com Explains all wiring options you should check it out.
0
06HEMIRAM
you should also be able to find how to wire them on rockford fosgates site, on their wiring wizard.
I had 3 12's in my old Lincoln continental, and then the same 12's in my old blazer.
I believe they were wired to 1.33 or 1.67 ohms.
0
06HEMIRAM
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
there's the link to fosgates wiring wizard. just plug in 3 for the quantity, and then select your voice coil configuration. It should probably give you 2 different ways to wire.
LndRanger86
THANKS
IB2LOUD's avatar
IB2LOUD
the impedance (ohms) doesn't have to be a rouded off number, just so long as you don't go below the amps specifications
aerodeck
im running 3 jl audio 12's, sounds great, 1 ohm load, amp is 1 ohm stable... ( lower the ohm load, the less resistance to the speaker, more bass with less watts!!! ) i'll try to find wiring diagram for you...
