Any tips on painting in the garage
13 following
gkellison46@gmail.com's avatar
truck action's avatar
truck action
Have to re prime,& went to paint at this time,. Will do it in the garage or tent off in the driveway.I've read all the forms I can find,about positive pressurizing the area,using box fans w/ filters & filters on the other side of the area. Any advise please!
Uncle Fester's avatar
Uncle Fester
Ventilation, ventilation, ventilation
oh and a good mask.
Make sure no pilot lights or gas in the garage. Anything flamable, be careful for sparks.
dirkbelt's avatar
dirkbelt
the guy that painted mine did it in a garage and it looks like it was done in a booth,its all about the prep,ventilation,and wetsanding and buffin.
truck action
Edited: 7/13/2007 6:05:29 PM by truck action
Got a 12x12 E-Z up, & will wrap it.Use in driveway, the garage is out! Plan on pushing the air through w/ 3 box type fans w/ filters in front & filters at vents other side,positive pressure. This way not pulling fumes over fan!Explosion proof fans are very expensive! Also got a paint approved mask w/ double filters.
lowgmc's avatar
lowgmc
SOME OF THE BEST JOBS COME STRAIGHT OUT OF A BACKYARD OR GARAGE! GOOD LUCK BROTHER!
get twisted's avatar
get twisted
right before you spray wet down the drive way so dust doesn't kick up will your spraying and it helps from over spray sticking to the cement
F
FKAHNDA
wet the floor down, but becareful of the hose getin wet and possibly dripping on the hood or roof. i have painted in a garage and in a makeshift booth outside when i cant sneak a car down to my work and spray it. The only advice i can give you is to ventilate the area, wear a good mask, and dont be stingy with the clear so u can sand on to get your dirt out but still have enough millige so the clear doesnt breakdown or delam on you.
-Trigger
truck action
Thanks for all the advise. Started building the booth,got one side covered & two of three fans in place. Will put a tarp on the ground.Read where static could be a problem, & to mix a 50% solution of rubbing alcohol & water & spray the floor & sides down?
injunjoe's avatar
injunjoe
what i have always done is built a make shift booth by hanging plastic (u can get it at walmart) from the ceiling to the floor be sure n weight the bottom to keep it from moving when u turn on the fans and also lining the ceiling, wet the floor make sure u clean the crar and tack it off really good and have a good water seperator, u shouldnt have a problem. LIGHT+ good water filter+ ventilation and u will be good to go hope this helps
truck action
Here's the first parts
