Page 1 of 3
Air Ride Suspensions \  oasis compressor
oasis compressor
Air Ride Suspensions Q & A
views 736
replies 23
following 14
Small Froddy   +1y
anybody else had problems with oasis compressors killing batteries, i've got 2 deep cycle batteries and a 190 amp alternator and this thing just keeps dragin em down, if anybodys got any ideas that'd be badass thanks
Low_SST   +1y
i run run an edc instead.
Small Froddy   +1y
yeah... it just sucks payin $700 for the thing and it's givin me nothin but problems for about 4 years now
thacru78   +1y
It pulls alot of juice man......like 180 amps. That can drain batteries really fast.
IB2LOUD   +1y
have you tried bigger gauge wire? seems like if you use smaller gauge wire, you'll have to supply more amps to keep the voltage where it needs to be. I would guess that thing needs what, like 0 or 00 gauge power cable if it's ran any decent length
Small Froddy   +1y
the wire's pretty thick, it's weldin lead that's suppose to be used for an arc welder
Small Froddy   +1y
none of you other guys have had problems with these? this thing has killed 5 optimas now, i see a lot of other folks that run these there's gotta be somthin i can do
IB2LOUD   +1y
how big is that wire? to carry that kind of current across a distance you're going to need some stuff that's like 1/2-3/4" thick, I would even run that to the alternator since it's a high output
stcaddad   +1y
you need like 250amp altenater to run thous
Small Froddy   +1y
the wire is that thick and run to the alternator
