nitrogen ?
13 following
nitrogen ?
coinslot1027
i am new to nitrogen, i got everything hooked up and works great but one thing is when i lift the truck once it uses 100 psi. i dont have a holding tank it is t'd off the reg. to the valves. will a holding tank help. or is this just how it is? i prob only have room for a 2 gal. will this even do anything? thanks in advance
TwistedPhil's avatar
TwistedPhil
How large is your bottle?
Adding a holding tank will make your system more responsive, but it won't affect the amount of air used on each lift. Even a 2 gallon tank, if it has individual ports for distribution to your bags, will give you a noticeable increase in performance.
But if your bottle is small, you might consider having a compressor tied in as a backup!
-Phil at FBI
Low_SST's avatar
Low_SST
be fully aware that shit goes fast, I used to blow through 370 cf every other week
coinslot1027
i am not sure the bottle is like 4ft. i want o say 125cf. but not sure. i will prob. just get another nitrogen tank for backup.
ShakinPlates's avatar
ShakinPlates
Just get a lil 3 gallon tank...
Its always a good idea to use a holding tank. bottle to bag seems risky to me.
I have friends who will blow a whole bottle in a day. Its all in how happy your fingers get...
ShakinPlates
Originally posted by ShakinPlates
I have friends who will blow a whole bottle in a day. Its all in how happy your fingers get...I JUST REALIZED HOW GAY THAT SOUNDS...
trucklover
wow that's pretty funny!!
trucklover
I wouldmake sure that you have that bottle in as safe of a place that you can find in your truck. I run a 40 cf bottle of nitrogen on my bagged go kart and you just gotta be real careful. I don't know about using it on a daily driver though. Those bottles are very dangerous at 2300 psi. Thts about what mine is topped off. I would recommend going with some sort of compressor just because you won't ever really need to get over 200 psi. Much safer got you and everybody else on the road.
coinslot1027
ok here is a ? when they filled it they only gave me 1500psi. what does everyone else get when theres are filled? you are saying 2300psi. am i getting dicked here?
DOWNSUB's avatar
DOWNSUB
^ A lot of things come in to play like what size your bottle is and the temp it was filled at.
s10
last post by baha +1y
