Mini Truckin General \  C-10 body droping question???
views 552
replies 11
following 8
02ramon20s   +1y
OK when traditional or stockfloor bodydropping a truck on 20-22s. Must you Z the Front Frame and why must you dont that?
KNDAlow   +1y
z'ing is really more a matter of getting the frame to lay out flat. it raises the front crossmembers so that the control arms dont lay on the ground. in doing so it will also lower the body some, pending on how big of a z you choose to do, which will make the bodydrop smaller.
bodydropped   +1y
you dont have to but the frt x member is lower than the frame but kp is selling a frt x member that will lay frame on a 29inch tall tire but if you use that then you could drop the body mounts and not have to b/d the truck
02ramon20s   +1y
what is the link for kp
bodydropped   +1y
http://www.kplinks.com the frt kit changes the steering to rack and pinion steering im ordering 2 of them once i get the cash
purplekush   +1y
if its a 73-87 u z the frame about 2.5-3 inches and cut the frame under the cab that sticks out and put a straight piece of 2x4 tubing to get rid of that curve and it will lay flat rockers on a 20 maybe even a 22
hammered   +1y
That crossmember is a porterbuilt part... we sell those for $1399
blazn   +1y
I have mine and it is worth every penny!!!
www.porterbuiltstreetrods.com
KNDAlow   +1y
that is a very nice part but thats a LOT of money. i couldnt see spending that much. after doin the work that i did, id still do the same thing
Wicked Fantacies   +1y
Correct KP just sells porterbuilts crossmember. Can't wait to get mine.
