Traditional Bodydrop with stock hood and motor mounts?
12 following
ccscotty06@netscape.net's avatar
laydsuzu's avatar
laydsuzu
is it possible to do that on an isuzu hombre or chevy s10 with a traditional bodydrop? no i dont want to put a cavilier manifold on it.
laydsuzu's avatar
laydsuzu
bump bump
dubDyme
why would it matter if it was a traditional or stockfloor bodydrop? but yes its possible
laydsuzu's avatar
laydsuzu
its matters cause I want to keep the stock hood with a traditional bodydrop the question is will i have to lower the motor mounts or can they stay where theyre at?
lo75lux's avatar
lo75lux
Edited: 11/19/2007 6:06:21 PM by lo75lux
how much of a bd? what is it to lay rocker on a s series? 3.25? and is a 4 cyl or v6,that has alot to do with it.
laydsuzu's avatar
laydsuzu
its an hombre, has a little higher hood than an s10 i believe, and its just enough to lay rockers someone told me 2 3/4 and its a 2.2 4 banger
eks10BDRG-N's avatar
eks10BDRG-N
section oil pan and motor mounts i think. your intake is the square looking so a caviler intake is not a option i believe
CC
creative concepts
the 2.2 is the motor you swap a cavy onto.
yes you can keep the stock hood.. lower the motor down some.
layeddime's avatar
layeddime
u will have to lower the motor for sure if you dont want the cavy intake. i just put a cavy intake on and it was easy to do. its alot easier to do the intake over lowerin the motor but its your truck do as u please.
laydsuzu's avatar
laydsuzu
I think i might just get an old hombre hood and put a cowl on it and paint it or cut out my one i have now and color match the stuff that comes above it. I dont want to go through all the trouble of sectioning the oil pan and stuff even though its the right way to do it
