83 hilux help
83 hilux help
F
framedragger
im body droppin my 83 and i need some info..i have heard that i can cut the frame down( under the cab) and pu t 2x3 square tubing in to body drop the cab.. can i or do i need to cut the floor...and any pics of the front set up would be greAT....and where do i put the strut bars...im just wanting to lay rocker...any help would be great..this is my first body drop....im not in any hurry...
lucky_brew's avatar
lucky_brew
you need to ask "twisted minis (seth bomar)" he has this model truck bd. i know everything about these trucks other than doing body drop. i do know you will need to convert the front suspension, brakes, etc to 84 or up stuff... also you will need to notch the steering arm to clear the oil pan when you z the front clip. but im not sure how this applies to doing a sfbd.
lucky_brew's avatar
lucky_brew
>>> not to jack your thread but do you or anyone who reads this thread have the chrome cab vents (79-83) or chrome square-type headlight doors (82-83) youd like to sell?
im looking for some in good shape!
thanks for letting me jack a little space john!
good luck with the toyota- they are truly one of the best body style minis ever built! ive had 3 of them!
F
framedragger
im gonna probably v8 it or put a 4.3 in it.im just wonderin about the cab body drop/
F
framedragger
http://a757.ac-images.myspacecdn.com/images01/85/l_9801ad853a86f9c0480144df36774124.jpg
here is a pic of the start..i dont know the image code here
lucky_brew's avatar
lucky_brew
Edited: 12/25/2007 3:38:45 PM by lucky_brew
here is the pic. i posted it up for ya. here is the site i use to make an html code to post in the forums. its easy...
http://www.somemyspacecodes.com/image-code.php
looks like you got a ton of work ahead of ya !!!!!!!!!!!
F
framedragger
i have plenty of time..thanks for posting that
tooleyhc's avatar
tooleyhc
NO KIDDING!!!
lucky_brew's avatar
lucky_brew
no prob! just use that link, its easy.
looks like you might need a part or two. if you come across those chrome parts i mentioned - hit me up.
also, are you looking for anything imparticular for yours?
TwistedMinis's avatar
TwistedMinis
You could cut down the frame. Its not that hard, just make sure it stays straight.
